KFZE VRIS POINTS?
KFZE VRIS POINTS?
ok as the title says, i want to know what are the vris points for the kfze ecu? at what rpms they open and close
same here :/ bohoo i guess if you have the right manifold weith right ecu it would be nice. as far if you have a klze manifold and a kf15 ecu the vris opens at 3.3k rpms, second opens at 5k rpms, they kick u back a bit in the seat..vris one is closed at idle (at least its always been that bcase for me) If you have a stock clutch .. even if this nengine isnt much the vris kicks will wear down your clutch a bit .. mine lasted around 8 thousand miles. why did u go kfze :S
lol jk
-hec
cant remeber the actual vris points off the top of my head, if i have time to day ill hook the kf15 ecu up and see what they are
01 Lexus Is300 (LS2 Project)
93 Mx3 SE 2.5 KLZE (sold it)
for me i havent checked bu i think they dont close.. again my car is screwed up at the moment, im pulling the engine as i type (laptop)
-hec
