im taking out my guages to put in new guage faces theres wiring in the back of my guages preventing me from taking it out how do i unplug it i h ave no slack to just pull it out and unplug it. thanks
Nick
i need help taking out my guages
- atlantamx3
To give you some more slack, you need to unook the speedometer gear that is actually on the transmission. The cable is JUST long enough to fit between the tranny and the cluster when the cluster is bolted in.
Once the cable is disconnected/pulled out from the tranny, you will have plenty of slack to unhook the cable from the back of the cluster.
- Limegreen mx-3
unscrew ur fuel guage so that u have space to slip the new guage on and then put ur fuel guage on. the fuel/temp guage people break them i know i did it once and it sucks.
i already took care of it, you were right about unhooking it from the speed sencor. but i did it on accident i pulled it out. couldnt figure out why my mph wasnt working lol, but i got it now. however, i messed up my rpm needle some how it sticks, its off timing and everything, how can i fix this s.o.b.
