ATX to MTX Reverse question
Posted: April 22nd, 2006, 8:15 am
by BoOdOg
Ok,
So in a 94 RS doing a ATX to MTX swap. Is their any way to hook up the reverse lights? Swapping harness would be the only way I see but I do not want to do this. I figure I could hook it to a switch but I would much rather have them come on when I put car into reverse. Any information be great thanks.
I did search and found some information on KLZE atx to mtx swap but nothing about the reverse lights just about jumping a plug.
Posted: April 22nd, 2006, 2:34 pm
by Grants
The MTX will have a reverse light switch in it so you would just need to swing over the wires from the park / neutral switch to the reverse switch. The colours to use are RED / GREEN and BLACK / RED and can be seen here:
http://eunos30x.com/info/1994%20Wiring%20diagrams.pdf
page 50.
Posted: April 23rd, 2006, 10:21 am
by BoOdOg
thanks for reply the link is dead, any chance you can post that pic?
Posted: April 24th, 2006, 7:45 am
by BoOdOg
sweet site worked today from work ... thanks man
Posted: April 25th, 2006, 6:57 am
by BoOdOg
in case someone ever searches it
when doing DOHC ATX to MTX to get car to start
you must connect the netural safety wires they are located at the very end of the automatic harness (big orange plug
your looking for the two larger wires in the series blue/black and red/black
connect them.
Now for your reverse lights find the backup lights switch on your manual tranny should be 2 wires going to a plug and one wire looped on the plug. cut the 2 wires off and connect them to a red/green and black/yellow wire from the same series as you found the netural safety wires
this may help someone works perfect on my 94 ![Smile :)](./images/smilies/icon_smile.gif)
Posted: April 25th, 2006, 10:08 am
by JWMX3
BoOdOg wrote:when doing DOHC ATX to MTX to get car to start
you must connect the netural safety wires they are located at the very end of the automatic harness (big orange plug )
connect them.
Thats fine for anyone who wants to do it like that.... but I'll just throw this in
If you want to have actual working neutral safety instead of just bipassed, run 2 wires from the same 2 you just connected thru the firewall and solder them to the switch on the clutch pedal. only takes 5 extra minutes ![Idea :idea:](./images/smilies/icon_idea.gif)
