EGR Problems
- Custom_V6_Limited_SE
EGR Problems
OK, my CEL came on and was staying on constantly so I pulled the code and got a 16. So, I decided to disconnect the EGR and see if it ran better. It did, but, after a while I smelled something burning and then the CEL turned off. I stopped and got 16, 28, and 29 which doesn't surprize me since I disconnected the modules assosiated with 28 and 29. Was there something else I was supposed to disconnect other than the two EGR solenoids? Does anyone know why it smelled like something was burning and then the CEL went out? (No, the CEL did not burn out)
Last edited by Custom_V6_Limited_SE on April 20th, 2006, 9:59 pm, edited 1 time in total.
'93 MX-3 GS SE:My Mods
- 1992blazeredgs
Even if you disconnected your egr, this might not solve your problem because alot of egr valves get stuck open causing exhaust gas to enter the motor constantly, even if you disconnect it in your case. I would take the egr valve out of the car and inspect it to get a better idea of why your cel was on.
Nate
Nate
Looking for another Red GS.
What should I remove? The valve and the solenoids? Is there something I would have to plug?
I am removing my EGR system right now...is it ok to remove the EGR valve? Because, I am in the process of removing it and I noticed that it mounts to the engine with a gasket. Does it go to anything? If so, what?
OK, I just got a mid-sized line off of it (which I thought was a IM line due to the online shop manual) and coolant started coming out. What's up with this? Do I have to leave that whole assembly on the car?
OK,
I found the other coolant line and those go from the TB to the EGR valve and then keep going through the system. I'm guessing that the port that the EGR valve bolts onto is the intake port. So, I will re-rout the coolant to bypass the EGR valve, but, what should I use to seal the intake port and exhaust port
![Idea :idea:](./images/smilies/icon_idea.gif)
![Twisted Evil :twisted:](./images/smilies/icon_twisted.gif)
OK, finally finished
. I made sure the EGR valve was closed and left every thing hooked up except for the ECU connectors (which took forever since I took everything off, reconfigured it, put everything back on, and then put everything back to the way it was
). It has never felt so good to see the CEL on lol.
![Welder :welder:](./images/smilies/welder.gif)
