Does anyone know if a Distributor from a Probe v6 stated to be over 200 HP work in a MX3 standard K8 v6 engine. I have an oppotunity to buy
one cheap as a spare, just in case mine goes bad , but I don't know if it will fit my MX3 V6.
Thanks for any information with this question.
Ford Probe V6 Distributor into a MX3 V6 will it work
Owner of 7 different cars, 5 being convertibles. 1990 Miata is one of my summer fun cars. I enjoy that car so much, I thought owning a MX3 would be fun also. Drive with your top open or top down. See my car web site at http://www.cardomain.com/ride/816145
- XxantwawnxX
THE distys from 93 and up probe GT's will work...you dont get any more pwoer from it. I alwasy order the probe ones from advance cause there cheaper then the mx3 ones.
- 93-Spec-Edn
