Turbo on a FS?
slimmyslim1420
Turbo on a FS?
Post by slimmyslim1420 »
Is there a direct bolt on turbo manifold for the 2.0 FS? If there is will it work on all years? And where can you get them? Or better yet does anyone make a kit for them?
1992 GS ZE swap 94 dash swap drilled and slotted rotors full ceramic pads CS SS clutch and brake lines KL-36 ecu zx-2 tokico struts eibach springs short shifter Tenzo exhaust Hi flow cat 2.5 in piping
ariesdude
Post by ariesdude »
94 Mx-3 Precidia
slimmyslim1420
That kit would work on a 98 626 wouldn't it. The engine looks identical. It says 99 and up so I wasn't sure.
Return to “Forced Induction”
