KLZE engine/trans mounts info 5SPD
Posted: March 11th, 2006, 11:47 pm
I need pictures of how the mounts should look like for instaling a KLZE 5spd in a MX-3
Car---> Mazda MX-3 V6 GS (it was auto)
I'm swaping in a (J-spec) Straight Neck KLZE 5spd into a V6 MX-3 auto.
I will be doing some work to the brake master cylinder but I need the engine to sit it the engien bay the way it has to, before I can start work on BMC.
I need some pictures (I would appreciate pictures or info of car mounts that I can use for "SN" KLZE.
Can I use any of the mounts from the K8 Auto??
Here i have PIC of my engine with numbers I put on for the mounts, please refare to these numbers for the mounts you are talking about:
No.1= Passanger motor mount under coolant hose neck
No.2= Front transaxle (radiator side) mount
No.3= Transaxle top mount (underneath battery)
No.4= Transaxle back (firewall/bulkhead) mount
I have the engine mount on the No.1 mount and bracket, I tried No.2 mount but makes the engine sit too much foreward(engine looks kind of crocked when looking from side). I dont have the No.3 mount, and the auto No.4 mount does not fit on the MTX.
Off of what car can I get these mount so they work, pictures of the No.3 mount would be appreciated as I have never seen what that mount with the bracket that bolts up to the frame looks like.
When I get the engine place correctly in the engine bay, I will do some work to the BMC as that is the only thing that seems to be in the way of the KLZE clearing the engine bay, it seems simple to go by, but need engine in first.
THANKS
THANKS
