Alberta Oil Jobs
Alberta Oil Jobs
Hey does anyone know how to get a job in Albertas oil sands?
i donno my ex gfs dad and brother are out there working.... my cousin is an oil rig engineer near sylvan lake i believe its called.... i donno i can see what companies they work for and let you know?
- Franko
I had an alberta oil job once.. I think its kind of like a cleveland steamer except you can choose what kind of oil you want to use.. I chose tropical orange.. I recomend it.
- Flashpoint2
I work in the Alberta Oil and Gas industry
06 Eclipse GT *Sold*
08 Evo X GSR *Current*
Re: Alberta Oil Jobs
Same way you get a job anywhere else. Try halliburton.mr_icez wrote:Hey does anyone know how to get a job in Albertas oil sands?
