What does this mean?
Posted: February 22nd, 2006, 1:38 pm
by Janus P
Hi.
When I turn off my engine, the speakers says.
BIBBIB_BIBBIB___BIBBIB_BIBBIB___BIBBIB_BIBBIB
What does that mean?
Posted: February 22nd, 2006, 2:07 pm
by Tunes67
Dude... your car is picking up alien transmissions from outter space!!
Actually.. its probably a bad ground somewhere.
Tunes67
Posted: February 24th, 2006, 12:22 am
by freakyalien
Yes, I heard that my cousin recently sent out a signal...dont' happen to remember what it says, however...
Posted: February 25th, 2006, 5:41 am
by jschrauwen
If you take a bunch of tin foil and shape into the shape of a cone and then put it on your head, it's supposed to (but I've never tried it myself though) clear up the static in those messages. It's been rumoured that when it happens you can also wear the tin foil reciever and touch one hand on the speaker and outstretch the other arm and slowly rotate your body to find the best reception direction - that I know has been proven.
Posted: February 25th, 2006, 8:44 am
by twoie
quite possibley your cars is in the beginning stages of tourettes syndrome. When the BBBBB finally comes out you won't be happy!
twoie
Posted: February 26th, 2006, 7:48 am
by Janus P
well just read some place. that it was some kind of error messege. For example it speakers BIB like 6 times airbags not working and so on........
Posted: February 26th, 2006, 11:44 am
by Tunes67
I have never heard or read anything like that for our MX-3's. However.. seeing as that you are in Denmark.. I suppose anything is possible.. though I seriously doubt it. What year is your car? Is your car equipped with a Check Engine Light?
Tunes67
Posted: February 26th, 2006, 2:55 pm
by Janus P
Tunes67 wrote:I have never heard or read anything like that for our MX-3's. However.. seeing as that you are in Denmark.. I suppose anything is possible.. though I seriously doubt it. What year is your car? Is your car equipped with a Check Engine Light?
Tunes67
It´s a 1.6 dohc 94´
Have a look at this topics.
http://www.mx-3.com/phpbb2/viewtopic.ph ... ght=airbag
Posted: February 26th, 2006, 3:51 pm
by Tunes67
I see why you might draw that conclusion.. but the beeping he is referring to is the same kind of beeping you get when you leave your lights on or when you leave the key in your ignition when you open your door. You are saying that you are hearing a sound from the stereo speakers correct? Even if you have a factory stereo still in your car.. I dont think you would be hearing any sound indicators from the speakers for errors. I cant say this will 100% certainty.. but either your original post is misleading or the two sounds are different between your post and that other thread.
Tunes67
Posted: February 26th, 2006, 3:58 pm
by Janus P
Tunes67 wrote:I see why you might draw that conclusion.. but the beeping he is referring to is the same kind of beeping you get when you leave your lights on or when you leave the key in your ignition when you open your door. You are saying that you are hearing a sound from the stereo speakers correct? Even if you have a factory stereo still in your car.. I dont think you would be hearing any sound indicators from the speakers for errors. I cant say this will 100% certainty.. but either your original post is misleading or the two sounds are different between your post and that other thread.
Tunes67
yes it comes from factory stereo speakers. okay thanks. just thougth that there were some kinda problem with the car..
Posted: February 26th, 2006, 4:19 pm
by Janus P
I have installed an Amplifier connectet to speakers, but the beeping sound don´t come from them. it comes from the original rear spekers that is still connectet to the headunit. I don`t think it has nothing to do with the headunit because it made the same beeping with the old unit..
do you undestand what i mean? it´s not so easy for me explaning it in english..
Posted: February 26th, 2006, 11:44 pm
by freakyalien
Well...maybe someone who owned the car before him rewired the noise for the airbags (seatbelts, doors, etc.) to the speakers..?
Maybe they were deaf and had a bad habit of not putting their airbag away before starting to drive.
Posted: February 26th, 2006, 11:52 pm
by Tunes67
Let me ask a couple of questions here... You only hear the sound when you shut off the car right? Does this happen every time you shut down the car? Or only in specific places or locations, like you only hear it at home or at work or at school or where ever.
Tunes67
