New member + question on cruise control
Posted: February 7th, 2006, 5:43 pm
by Rotorhead87
First of all, I'm a new member. I just got a green 1993 MX-3 4-cyl about 6 months ago as a daily driver. My other car is an '87 RX-7, which I am currently rebuilding the motor on.
Now for my questions. Basically, I want cruise control, but the car didn't come with it. I found a GS with cruise control that I can pull the parts from. Would this work? I know the TB's are in different places, but as long as the mounting bracket for the cable is the same distance from the TB it could work, right? Also, is all the wiring present, or would I have to add some wiring to make it work? Thanks in advance.
Posted: February 8th, 2006, 2:48 am
by PATDIESEL
I don't know if all the cars were prewired for cruise, but a GS donor car should get you all the parts you need. Get a pic of a RS with cruise for the vaccum tap location and the rest is basic replacment of parts.
Welcome to the forum and good luck with your MX-3.
Posted: February 8th, 2006, 11:03 am
by Rotorhead87
Thanks for the help. I have a base RX-7 and all the wiring for all possible options is put in the car. For example, all the wiring for the cruise control was there, plus all the wiring for the rear wiper is there. I guess I can get the parts and check it out. They only charged me 20 bucks for the cruise for the rx7, so its not much to lose.
Posted: February 8th, 2006, 2:18 pm
by ariesdude
Please keep us updated - I am interested in this conversion too. What are the parts required for the conversion? From an old post it looked like if you have the SOHC engine - you would need the entire wiring harness replaced ...
http://www.mx-3.com/phpbb2/viewtopic.ph ... se+control
I am assuming that DOHC might have the harness in place already. So what else would be needed ...
1) Cruise control main switch (dash)
2) Cruise control switches on the steering
3) Cruise control box in the engine bay
4) The cable that goes to the throttle body
5) The vaccum line
Posted: February 9th, 2006, 10:18 am
by PATDIESEL
There is no cable that runs to the TB for cruise. That is on auto trans only and is used to tell the tranny how much gas you are giving the car. Other than that you list looks complete.
Posted: February 9th, 2006, 1:19 pm
by Rotorhead87
If there isn't a cable that runs to the TB, then how does the cruise control work? In the cars I've seen, there is a cruise control unit that is attatched to the TB linkage next to the throttle cable. There appeared to be one on the GS I looked at.
Also, if I do have to mess with splicing wiring harnesses and stuff, i may just forget about it. I'll have to look into it more to be sure.
Posted: February 11th, 2006, 11:10 pm
by ryanlindenberg
I dunno for sure how the MX3 works but the IACV or something similar could control the cruise speed.
Posted: February 13th, 2006, 2:22 pm
by Chemical
I'm interested in this too but for V6, anyone done it?
Posted: February 14th, 2006, 12:04 am
by TREVO123
Cruise control are for lazy ppl...acidents can happen with them/ :!:
Posted: February 23rd, 2006, 10:51 pm
by oceanline
Yeah I can kinda see your point, but cruise is so awesome on the hiway
