why cant i sleep?
why cant i sleep?
RAAAAA
Its 5:30 am if i try to fall asleep and actually suceed ill be up again by 9am! WTH is wrong with my me!!! i guess my body doesnt like to sleep, to bad cause i sure do
anyone else like this?
01 Lexus Is300 (LS2 Project)
93 Mx3 SE 2.5 KLZE (sold it)
- 93-Spec-Edn
did u sleep in the day before? try to get 7-8 hrs sleep and no more. Also a cooler temperature bedroom is better. Barry is right in that u should avoid stimulants and sugars b4 bed. Also a hot glass of milk (flavoured) would help as milk has tryptophan which induces sleep (also tryptophan is a prescription drug for sleep). If u can't sleep after 15-30 mins get up and do something non stimulating for 15 mins and then try again.
goodluck.
goodluck.
92 mx-3 RS RIP | 95 mx-3 GS sold | 93 mx-3 GS SE sold | 95 mx-3 GS present
- Flashpoint2
cures for no sleep are as follows
1) Smoke pot- illegal in most areas but effective
2) Have sex or masturbate- It's a proven fact that when a man ejaculates his body releases a chemical that makes him tired.
3) exercise- this helps release unwanted energy so you can sleep.
4) take sleeping pills
Teal 1993 MX3GSZE
Like he mentioned they're all true. Go spend $60-$80 on a boxing bag and spend 10minutes a night letting out some anger. You'll soon put yourself to sleep.V8KOMX3 wrote:cures for no sleep are as follows
Or if you dont wanna spend money do situps/pushups
Ever notice anyone driving slower than you is an idiot and anyone driving faster than you is a maniac?
01-03 Civic Projector Swap Tutorial
- GregoryChristian
i know that if you are trying to lose an excessive amount of weight in a short period of time, it may mess up your sleeping routine. it happened with me and well it sucked. so i just thought that id throw that out there
- Flashpoint2
