mustang svt injecotrs??
Joey's mx
Post by Joey's mx »
would ford mustang svt injectors fit on a DOHC b6 harness?? Are they low or high ependance and what cc are they??
SnoSurferr
Post by SnoSurferr »
Ummmm.....
azazel95
Post by azazel95 »
SnoSurferr wrote:Ummmm.....
:P Bout the same as me... no idea.
93_mx3_gs
Post by 93_mx3_gs »
Why would you want ford injectors in your mazda ? o.O do't ghettofy it.
Joey's mx
Post by Joey's mx »
the same reason poeple put FORD PROBE injectors in there car!!
93_mx3_gs
Post by 93_mx3_gs »
Because they want a ford and not a mazda ? Odd.
nicksmx3
Post by nicksmx3 »
mazda is distantly owned by ford
93_mx3_gs
Post by 93_mx3_gs »
Mazda isn't 'Owned' by Ford, they just have a massive amount of stock.
azazel95
Post by azazel95 »
They own the controlling interests so basically they own them.
93_mx3_gs
Post by 93_mx3_gs »
The more people own individual shares such as small time investors and large scale investors than Ford does. Ford just wants to be a controlling factor.
nicksmx3
Post by nicksmx3 »
ford actually owns a lot of other companies. volvo, land rover, as well as lincol and mercury. my fiance's dad has worked for ford for like his whole life.
93_mx3_gs
Post by 93_mx3_gs »
I thought Land rover is a model of Toyota...
azazel95
Post by azazel95 »
They all own stock in eachother's company. All intertwined. They should just all merge and change the name to "Auto" :P
reaper of souls
Post by reaper of souls »
ok so if ford doesn't own mazda then tell me why there is no differenct between a ford escort and a mazda protege (up till 97 of cource) and then even so they also are the same vechicle as a mecurcy tracer
and i should add the v6 in the mx3 is the same in the probe till the second gen the it has the same v6 KLZE as the mx-6 !!!!!!!!!!!!!!!!!!!!
so on that note Ford indeed owns mazda (although it hasn't been till recentlly that mazda has changed the look of all there cars as to not look like the ford counter part too bad because i want to see a new look for the b2200 i already had a ranger something more then the grill has to change )
reaper
Image 96 X-90 4x4, 16v custom ram air intake lockers front and rear with 5.83 ring and pinion.
ariesdude
Post by ariesdude »
Mazda Motor Manufacturing (USA) Corporation (MMUC) (Flatrock, MI) is basically a company setup by the parent mazda corp to manufacture vehicles in US in 1984. Ford acquired 50% stock in Mazda Motor Manufacturing (USA) Corporation (MMUC) in 1992. The company was renamed AutoAlliance International, Inc. and was announced as a joint venture between ford and mazda. The parent company (mazda) has a separate office called Mazda North American Operations in Irvine, CA. So mazda as a parent company still exists and is independednt from ford. And since ford has only 50% (not 51% or more) of shares - its a partnership - ford does not own mazda usa. Any decision has to be agreed upon by both company board members (atleast according to the official version). Ford and mazda had agreements dating back to 1984 to produce engines/transmissions for each other's cars in the north american market. They do all these buisness deals so they can save quite a few bucks on taxes, duty fees etc. In the end all these companies exist to make money - making good cars is a good side effect i guess
94 Mx-3 Precidia
