strut / shock mount question!
Legato626
Post by Legato626 »
Sense x-mess is over and I am starting to get the cash flow back I am going to do my suspention. What I am asking is for better struts and shocks i am planing to replace my bad mounts with new ones. Is it ok just to use a new per of stock mounts or should I go to a better set? And for dust boots would stock ones work fine or are there better ones I should go with?
I am going to be using tokico blue's and H&R springs.
1994 toyota supra single turbo
1994 Mazda MX-3 KL-ZE
If god owned a car... It would be a supra!!!
JWMX3
Post by JWMX3 »
stock mounts and boots are all you need
Mazdaracer
Post by Mazdaracer »
may i suggest the ZX2 S/R struts over the Blues. They offer better valving, are designed with a shorter shaft stroke for lowering springs and all 4 can be bought for the price of 2 Blues.
I used the S/R struts and MX3 H&R springs on my Protege for awhile for autox and they worked very well together.
THINK FAST, GO RACING!!
2004 Mazda6 Wagon
2004 Mazda3 Sedan
1990 BG8P Protege LX - KLZE - Race Preped - #98 SM - SCCA Solo2
Mazdaracer
forgot to mention there are 2 extra parts ya need for the S/R struts (they still come out to be cheaper than the blues)
97+ Escort/ZX2 Thrust bearing and 97+ Upper perches.
- Ford Racing ZX2 S/R Strut Kit
Southwest Ford; Weatherford, TX
1-800-256-7933 - Parts Counter Direct line 817-596-5700
Internet Sales Manager - Terasa Valley
info@oemfordparts.com
http://www.oemfordparts.com
ZX2 S/R Tokico Strut Kit
P/N M-18000-Z2
Retail Price $175USD | Online Price $160USD
Front Strut Upper Bearing
Ford P/N F8CZ18198AAA
2004 Mazda6 Wagon
2004 Mazda3 Sedan
Legato626
Post by Legato626 »
I can get the blues for $87 bucks each. but i want to stay with the stock style because were i live. I dont want to get this car any lower. And for the mounts mazda dealer wanted to charge me $70/each for the rear and $76/each for the front!!! Went to checkers it was like $40 bucks for each.
Mazdaracer
that $160 price is for all 4, not each.
the shorter shaft stroke does not lower the car. The perch is still in the same position as stock. It just allows the strut to have a better working range, and not be constantly at or near the bump stop limits. The upper perches are identical, for the exception of a slightly larger hole for the thrust bearing. Mazda shaft is 20mm, the ZX2 shaft is 22mm.
2004 Mazda6 Wagon
2004 Mazda3 Sedan
