Did anyone do the Big Three with their MX-3?
- Mazdaspeed96743
Hi did any of you people do the Big Three upgrade? I am wondering if that helped you people out because I got an Orion 1200D amplifier and when I turn the music up running my 12 the music stops playing and at night the whole system shuts off and CD player blanks out and it comes back on 1 second later. I simply got some serious voltage drops.
- rsroadkilla
- FlyVFR
Sounds like thermal protection is kicking in. Or not enough current to power your AMP. Do you have a CAP installed?
Stock 92 MX-3 GS
93 MX-3 GS KLZE
98 BMW 328IS
81 Trans AM NASCAR Pace Car
80 Trans Am INDY Pace Car
www.MyMX3.com Domain For Sale!
My Feedback File
93 MX-3 GS KLZE
98 BMW 328IS
My Feedback File
- Mazdaspeed96743
Here is a great example of the Big Three Upgrade and it is supposed to be better than using a capicitor=
http://www.caraudio.com/vb/showthread.php?t=124175
- FlyVFR
Stock 92 MX-3 GS
93 MX-3 GS KLZE
98 BMW 328IS
My Feedback File
93 MX-3 GS KLZE
98 BMW 328IS
My Feedback File
- Mazdaspeed96743
- FlyVFR
Mazdaspeed96743 wrote: I am having a hard time finding the positive terminal on the alternator though can someone pinpoint where the + Wire from the alternator is?
*IMPORTANT: To reduce the risk of an electrical short (and possible meltdown) the fuse must be located very close to the battery terminal.
Stock 92 MX-3 GS
93 MX-3 GS KLZE
98 BMW 328IS
My Feedback File
93 MX-3 GS KLZE
98 BMW 328IS
My Feedback File
- Mazdaspeed96743
But the amp is already hooked up. All I did is run a 8G wire from the battery - to the chassis and tomorrow I am going to run another 8G wire from the chassis to the engine block. I need at least 4G wires though too small of a wire size for ground. heh well at least my amp is being feed by 4G power wires.
- PATDIESEL
The + on the Alt is the BIG wire that attaches to it....
Not trying to be too much of a Jack-a--, but geesh, how many wires do you see on the Alt?
- FlyVFR
Try that first. I bet you won't have to replace the alt. wire. Also keep in mind that the system will shut down if overdriven. Does it go out at 75% volume?Mazdaspeed96743 wrote:But the amp is already hooked up. All I did is run a 8G wire from the battery - to the chassis and tomorrow I am going to run another 8G wire from the chassis to the engine block. I need at least 4G wires though too small of a wire size for ground. heh well at least my amp is being feed by 4G power wires.
Stock 92 MX-3 GS
93 MX-3 GS KLZE
98 BMW 328IS
My Feedback File
93 MX-3 GS KLZE
98 BMW 328IS
My Feedback File
- Mazdaspeed96743
- FlyVFR
If you can't find it or have easy access to the alt wire, I would stop by the local audio shop and have them run it.
Stock 92 MX-3 GS
93 MX-3 GS KLZE
98 BMW 328IS
My Feedback File
93 MX-3 GS KLZE
98 BMW 328IS
My Feedback File
- Mazdaspeed96743
- FlyVFR
You'll probably need a cap to compensate for quick power surges as well then. Try the BIG 2 first.
Stock 92 MX-3 GS
93 MX-3 GS KLZE
98 BMW 328IS
My Feedback File
93 MX-3 GS KLZE
98 BMW 328IS
My Feedback File
- FlyVFR
Pat, sometimes it's a pain in the arse to get access and hook up a megawire to the alt. So I'm not going to push the issue.
Stock 92 MX-3 GS
93 MX-3 GS KLZE
98 BMW 328IS
My Feedback File
93 MX-3 GS KLZE
98 BMW 328IS
My Feedback File
