I wanted to keep the stock harness so i could put my old lights
back in if i wanted to.
The pictures i have are bad quality bc my digi is a peice. But here it is
-=STEP ONE=-
Take the wiring harness you got with the projectors
And take off the Black housing.
-=STEP TWO=-
You will see on the metal prods that their is a line down the middle of it
Do that to all three
-=STEP THREE=-
Then guess what.....
Its plug and play time...
Thats right.
Plug it into your stock housing.
IT JUST SLIDES IN.
*match the colors from behind the housing.
*ex"black wire=black
*red =red and the blue one hooks up to the last one
*(red with grey stripe).
Plug the original project harness into the projectors and YOUR DONE
* I recommend tiddying up the new harnes you made with some eletrical tap.Its all up to you.
____________________________________________
You can hook up your halos a million different ways
I just attached them to the projectors wiring harness.
Hope this helps everyone out. And if your thinking about doing this mod
YOU MUST...It makes your car 1000000 times more amazing to look at.
</pre>
