Power steering
Power steering
Hey all..the power steering has gone wrong on my car. Don't know what needs replacing/fixing / looking at. Anyone know what the most common problem is and how i make sure i know what to replace? Thanks.
- XxantwawnxX
Check the powersteerring fluid lvs first. If your car is not over heating then ur belt is still in place(uses same belt for waterpump and powersteering)
