Page 1 of 2
O2 sensors...4 wire or 3 wire uni's?
Posted: December 7th, 2005, 5:36 pm
by Spinkx79
I have had bad O2's for a long time and finally ordered some. I wasnt sure if i needed 4 wire, 3 wires or both (universals) so i bought 4 of each.
They came in today.
Anyone know off the top of their head which would be better? I believe the 4th wire is only a second heated wire.
My car is OBDII (96 GS)
Thanks
Posted: December 7th, 2005, 6:45 pm
by jschrauwen
You got 4 of them Eric? Sh*t, I've only got 2 in mine (4 wire type). Can't really say if the OBD II changed over to a different config. I remember seeing a thread about some members integrating the universal units to our cars including the correct colour code assignments. I thought you were going to go Wideband?
Have you started to assemble the "Super DE"?
Posted: December 7th, 2005, 7:18 pm
by hgallegos915
arent those extra wires for the oxygen sensor heater for cold starts? i was reading an article somewhere about those wires..forgot where
Posted: December 7th, 2005, 8:59 pm
by Nd4SpdSe
hgallegos915 wrote:arent those extra wires for the oxygen sensor heater for cold starts? i was reading an article somewhere about those wires..forgot where
Basically ya, to get them upto temperature faster to give the ECU a proper reading. Mine were 4 wires, and so were my stock ones...i spliced the wires from the new 02 sensors and cut off and used the connectors from the stock sensors do they'll just clip right in
Posted: December 11th, 2005, 11:13 pm
by Chiggles
As I understand it, 4-wire type for the GS and 3-wire type for the RS.
Posted: December 12th, 2005, 11:04 pm
by FlyVFR
Nd4SpdSe wrote:...i spliced the wires from the new 02 sensors and cut off and used the connectors from the stock sensors do they'll just clip right in
Good
Just match up the wire colors or is there another trick to it? Where is a good place to buy? Are the Bosh units any good?
Posted: December 13th, 2005, 10:27 am
by jschrauwen
FlyVFR wrote:Nd4SpdSe wrote:...i spliced the wires from the new 02 sensors and cut off and used the connectors from the stock sensors do they'll just clip right in
Good
Being from the Us, this might be the best/least expensive source.
Nopi Online - http://www.nopionline.com/nopistore/dsp ... N=35613893
973+0269 is the universal replacement for us. A search will reveal that I posted a number part numbers from Nopi Online wrt interchangability and compatibility with the MX6/626 O2's.
I wish we could get that sort of pricing up here. Usually 2 to 3 times more expensive before exchange rate and after all of the middleman's hands get a piece of it.
$42.87usd is pretty damn cheap if you ask me. Good luck.
*John*
Is it a WOXOF day out east? ....LOL
Posted: December 13th, 2005, 1:55 pm
by Spinkx79
I bought "borg-warner" 4 of each kind and paid only $20 per.
Posted: December 13th, 2005, 2:24 pm
by jschrauwen
Spinkx79 wrote:I bought "borg-warner" 4 of each kind and paid only $20 per.
Eric, does your OBD II utilize the 3 wire and if so I'll buy the 4 wire ones off you. I think the 3 wire ones can also be rigged to work on the 4 wire applications (OBD I) also IIRC.
Posted: December 13th, 2005, 7:47 pm
by FlyVFR
Thanks John. I will check out the NOPI products.
It's actually VFR weather. Baro 30.33 at 50ft, 18.5 F, 49% humidity and unlimited visibility here in CT .....LOL
Posted: December 13th, 2005, 10:06 pm
by jschrauwen
FlyVFR wrote:Thanks John. I will check out the NOPI products.
CAVOK
Posted: December 13th, 2005, 10:32 pm
by FlyVFR
Roger...Cloud and Visibility OK.
Posted: December 14th, 2005, 10:06 am
by Nd4SpdSe
Good
Atlthough i did them in spring, I don't remember the wiring colors, but I believe there was a diagram in the box to way which ones connects to which color...
Posted: December 14th, 2005, 12:14 pm
by Spinkx79
jschrauwen wrote: Eric, does your OBD II utilize the 3 wire and if so I'll buy the 4 wire ones off you.[/color]
John,
Why would you want the 4 wire ones, you dont drive your car in the winter so the second heated wire would be of no benefit to you...IIRC
I havent had a chance to check which ones i need or will be using.
Posted: December 14th, 2005, 6:09 pm
by FlyVFR
Thanks Nd4SpdSe. My first time changing the sensors after 186,000 mies
I'm looking forward to better gas mileage.
