Need some input on a weird ques
93-Spec-Edn
Post by 93-Spec-Edn »
Hi
Is there any way to drain a MTX v6 tranny other than the drain bolt?
Thanks
92 mx-3 RS RIP | 95 mx-3 GS sold | 93 mx-3 GS SE sold | 95 mx-3 GS present
solo_ryder
Post by solo_ryder »
You can always smash the tranny with a hammer. Or suck it out of the filler hole.
MX3 GSR for dummies
Post by MX3 GSR for dummies »
WHY?????? :shock: Reverse osmosis? :idea:
If at first you don't succeed....it never happened
94 mx3 GS w/ KLZE, KL31 ECU, clutchmaster stage 3, cross drilled rotors, Custom ram air intake, Custom exhaust, Toyo tires, 250LPH fuel pump, Modified Distributor, Upgraded Wiring etc, external HEI, Full Body Drift kit and freshly painted Grey. Interior neon accents and much more in progress
slimmyslim1420
Post by slimmyslim1420 »
Why can't you use the drain bolt?
1992 GS ZE swap 94 dash swap drilled and slotted rotors full ceramic pads CS SS clutch and brake lines KL-36 ecu zx-2 tokico struts eibach springs short shifter Tenzo exhaust Hi flow cat 2.5 in piping
lakersfan1
Post by lakersfan1 »
Pull the axle out and have 10 big guys roll your car on its side.
slimmyslim1420
Take out the speedometer gear and flip the car over.
jschrauwen
Post by jschrauwen »
lakersfan1 wrote:Pull the axle out and have 10 big guys roll your car on its side.
Way too funny ... I love it!!! :laugh:
93-Spec-Edn
The reason is my tranny has a crack by the drain bolt, so it wouldnt hold and fluid. As a result i welded the bold on using JB weld therefore it cannot be removed. I want to switch to redline fluid.
slimmyslim1420
If thats the case your best bet would be to suck it out of the filler hole with a syphon pump or something. Anyway good luck with that.
PATDIESEL
Post by PATDIESEL »
A syphon (or the like) will not work since you need to get the hose to the bottom of the tranny ot get all the fluid out. That is impossible since there are GEARS and such in the way of getting to the bottom of the tranny.
You should have found another way to seal the crack... I don't think you can drain the fluid ever now...
den
Post by den »
Drill a hole??? Yeah I guess that should work... then put some kind of valve in it or stick a cork.
1992 Mazda MX-3 GS 5 speed
Reverse glow gauge, Custom CAI, Cross drilled rotors. Toucan front strut tower bar, Custom circular ground wires, Custom exhaust w/ stainless oval dual tip muffler, Custom blue turn indicator lights on gauge panel and switches, performance steering wheel, Pacesetter short shifter
GQ084
Post by GQ084 »
Unweld it.... :lol:
