I just need the RPM gauge. I dont need the inverter nor the other gauges.
These are the ebay ones. (procarparts?)
When putting mine in this weekend, I noticed mine does not work.( just this gauge)
Some sort of short in it that keeps the others from turning on. I dont really wanna buy another set if I do not have to. If you have set with problems yet this one works, let me know.
Thanks in advance.
[WTB] reverse indiglo RPM gauge.
- ovendenk
i think mike_moss had some gauges he was trying to get rid of. it was a little while ago though. try sending him a pm.
kevin (aka The Oven)
93 mx-3 GS KL-ZE with KL31 cams and properly chipped ecu
All mods are on my website: http://ca.geocities.com/ovendenk
MX-3.com Worklog: http://www.mx-3.com/phpbb2/viewtopic.php?t=48462
- 2fazed
I had the same problem. And it was a short in the rpm gauge wire. It was because of the bend that occurs when you slip the wire out of the cluster. I just cut a portion off and reconnected it. Works fine now. Give it a try.
06 Mazdaspeed6 2.3T
93 626 ES 2.5
92 Mx-3 RS 1.6
93 Mx-3 GS 2.5
93 Mx-3 RS 1.6
06 Mazdaspeed6 2.3T
93 626 ES 2.5
92 Mx-3 RS 1.6
93 Mx-3 GS 2.5
93 Mx-3 RS 1.6
anyone know why my gauges flick on for 2 minutes then flick off for 30 min, then repeat? i have checked connections.
www.illegalCustoms.com
Tri-State Area Car Club
- Custommx3
- Site Administrator
tried, even eliminated the wires.. no go2fazed wrote:I had the same problem. And it was a short in the rpm gauge wire. It was because of the bend that occurs when you slip the wire out of the cluster. I just cut a portion off and reconnected it. Works fine now. Give it a try.
ok guys I still need one.
