To get my Starter/alarm to work properly, I needed to fix the switches on the doors that control the interior lights going on and off. This is obviously an easy task, and the passengers door was. But when I unscrewed the one on the drivers door, the wire wasn't even attached.
The hole isn't too big, and i've tried fishing for the wire with no luck. I haven't been able to find a way into that little compartment just infront of the quarter panel under the bottom of the door.
Any ideas?
