KINGSTON MEET - SATURDAY NOV. 26TH
- mymx.3
We can meet at the Kingston Centre between 6:30 and 7pm.
Later we can go to Tims or Kelseys ... wherever .... some place warm
This would be a good time for any Ottawa peeps to come see us. People from Trenton and Belleville could probably meet so you can come altogether. Toronto and others can join you also.
So I hope as many of you can come. Let me know if you can then I'll add you to the list.
Directions to follow.
DEB
mymx.3 - yes
ProspectMx3 - yes
Dave - yes
Shawn - maybe
bushidosword - yes
ovendenk - maybe
jschrauwen - yes
DEB
mymx.3 - yes
ProspectMx3 - yes
Dave - yes
Shawn - maybe
bushidosword - yes
ovendenk - maybe
jschrauwen - yes
- bushidosword
- ovendenk
well i'm free of the wifey that weekend, so probably can work. i don't know if you read my previous post about my car overheating, but that little event blew my water pump gasket. i'm having to put coolant in every other day when i'm only driving 60km per day, let alone 400km in a single day. that would mean that i would need 2 jugs of coolant.
i might be able to get away with some high temp sealant for a little while, we'll see. i do want to come though. i'm a maybe for now.
kevin (aka The Oven)
93 mx-3 GS KL-ZE with KL31 cams and properly chipped ecu
All mods are on my website: http://ca.geocities.com/ovendenk
MX-3.com Worklog: http://www.mx-3.com/phpbb2/viewtopic.php?t=48462
- ovendenk
btw i would appreciate it if it was earlier (ie. daylight) since this will probably run for a few hours and i have a 1.5hr drive home. thanks. still a maybe for now though.
- bushidosword
- jschrauwen
- ovendenk
getting more probable for me. got some high temp sealant and i'll steal the water pump seal off my parts car, so gasket plus sealant SHOULD hold up for a couple months. hopefully will get this done monday or tuesday cause i'm in guelph right now seeing the wifey.
andrew, that sounds like a good idea. will connect with you once i have more info on my car's status.
- bushidosword
- jschrauwen
Not really rocket science. Km's (from mapquest or good old fashioned road map) + your intended speed via 401 = time to Kingston. I've done it in 2.5 hrs a few times.
Haha, not happening. Map point indicates a 3:15hr drive, and considering that I get off of work at 6pm, it's not even close to being worth it.
