v6 manual conversion question.
Posted: November 10th, 2005, 4:37 pm
by skdrcr
Sup fellas.
Here's the question.
My buddy has a KLZE swap in his 93 mx-3.
Well the whole automatic transmission thing didn't work out so
were gonna do a manual conversion.
Do I need to use a 2.5 v6 transmission/shift linkages etc. out of a probe or out of an mx-6, or is it better to use the manual 1.8 v6 tranny
out of the mx-3?
Reason being, I know where a wrecked M/T mx-3 is but I don't want
to get it if the tranny won't work with the KLZE.
Thx, Chris
Posted: November 10th, 2005, 5:28 pm
by JWMX3
you need the linkage from an mx3
the tranny itself can come from any of the cars mentioned...probe,mx6,626,mx3
Posted: November 10th, 2005, 5:32 pm
by Custommx3
the PGT and MX-3 trannies are identical, the mx-6 has a longer 5th gear.
Posted: November 11th, 2005, 1:16 am
by PATDIESEL
Make sure to rob the master cylinder, brake booster, pedals, shift knob, actual shift lever, shift boot, slave cylinder hard line and rubber line (or get a stainless steel one from CorkSport) and the aforementioned shift linkage from the MX-3 GS at the junk yard.
Posted: November 11th, 2005, 1:27 pm
by deathman
why would you need the master cylinder, brake booster? i converted a mx6 with no problem with out the master cylinder, brake booster, but i know you need all the rest
Posted: November 11th, 2005, 4:57 pm
by JWMX3
you dont need the brake master cyl or brake booster... the reservoir on my original one just had a cap over where you plug the clutch line into
Posted: November 12th, 2005, 3:13 am
by deathman
so the master cylinder supples the clutch master cylinder it's brake fluid.
Posted: November 12th, 2005, 3:50 am
by PATDIESEL
I'm not sure of the differences, but they are not the same part number if memory serves me correctly. I also didn't know the atx just had a cap over the clutch line. :roll:
I guess make sure to check your MX for the cap and if it has one then you are in the clear about getting all the engine bay brake stuff. It will save a TON of time. The last MXT swap we did, the brake booster and stuff was about 1/3 of the time it took.
Great to know that they do have the slave cylinder port in the ATX MC. Thanks guys [even if about a year late]
Posted: November 12th, 2005, 7:18 am
by deathman
i think i only took about 8-10 hours to do the whole job on a mx6. i sent for time going to the junk yard to get the parts i misted the first time lol
