LED Turn Signal Knight Rider Style.
What do you think ? With the right color matching ( for me I'm white with blue. White car, blue brake calipers, blue silicone hoses, blue this, blue that ) It wouldn't look too shabby.
Need a control boxand relay to hook directly into the turn signals so when you click left, the leds run left in a endless loop until turned or turn signal level switch off and same for the right.
A little bit of fiberglass work to make a shell for them and mount them right in the stupid tiny grill insert area.
- freyguy_412
hey i think it would be cool, and unique!! i have a similer idea but for my thrid brake light and two ros of leds so that i get the top row starting from left to right and the bottom row from right to left
let me know how you make out if you go for it
Reaper
Greg
Reaper
Greg
96 X-90 4x4, 16v custom ram air intake lockers front and rear with 5.83 ring and pinion.
- MX-3 Money
- FlyVFR
If anyone is interested I can make available a circuit I designed a while back that will cycle 16 LED's back and forth. Speed can be adjusted. Also a version designed to cycle 16 bi-color LED's (Red-Green) 2 parten variation available.
Stock 92 MX-3 GS
93 MX-3 GS KLZE
98 BMW 328IS
81 Trans AM NASCAR Pace Car
80 Trans Am INDY Pace Car
www.MyMX3.com Domain For Sale!
My Feedback File
93 MX-3 GS KLZE
98 BMW 328IS
My Feedback File
- FlyVFR
Of the schematic or the prototype? This is an IC bases circuit that I can modify to reqired specifications. The original project simply flashed 16 bi-color LED's. email me for an avi sample.freakyalien wrote: Oh....hm...got a pic?
It can easily be converted to power LED's not mounted on the circuit board by using a suitable wire harness for any ap.
Stock 92 MX-3 GS
93 MX-3 GS KLZE
98 BMW 328IS
My Feedback File
93 MX-3 GS KLZE
98 BMW 328IS
My Feedback File
I found this on ebay - if anybody wanted to do the knight rider style lights (bit smaller scale)-
http://cgi.ebay.com/ebaymotors/RED-LED- ... 2921QQrdZ1
94 Mx-3 Precidia
I have one of those for my alarm.
