KL ZE boost question involeing an FMU ratio.
XxantwawnxX
Post by XxantwawnxX »
Ok i did a search on FMU and (on other combo's of words) and did nto find anything.
Sooner or later i plan on boosting my ZE with a T3 turbo . IM only planing on running 5-6 psi.
I would like to know what FMU would i need 8:1 10:1 or 12:1? As i dont want to run lean on boost.
I plan on keeping my stock fpr for idle regulation, is this wise or should i get an adjustable fpr?
Im running a 3rd gen rx7 pump and stock injectors
any info on this would be helpful, thank you.
Oh and i relativly new to forced induction,although i know alot (or i think i do) So if anything i wrote seems wrong, dont be to harsh. I might not know what im talking about : P
babyblueMX3
Post by babyblueMX3 »
most people use the 8:1 or 10:1 ratio
Another option would use the cartech fmu wich alows you to use the ratio you want by turning a knob
RIP 400whp ZE-T MX-3
nos92mx3
Post by nos92mx3 »
I also highley suggest a Wideband o2.
There not cheap but well worth it in the long run.
92' Rs-t b6t/De - RIP
93' Rs-t BPT - Sold
03' WRB wrx Wagon - Current
XxantwawnxX
Thanx alot for the info guys.
Return to “Forced Induction”
