I lost that tiny hose that goes on the side of stock air box
fir3
Post by fir3 »
Do you know about that tiny hose that goes on the side of the stock air box ?
Where does it go ?
Months ago I bring my car to a mechanic who installed the cone air filter.
He has disconnected that little hose... Now I purchased a cold air intake with the connection ready for connect that... But I can't find the tiny hose anymore :lol:
Where is it ?
StylinMike
Post by StylinMike »
Do you mean the breather hose coming off the valve cover?
fir3
Post by fir3 »
It's a very thin hose...
fir3
Post by fir3 »
Someone with the stock original air box can help me ?
Just find the tiny hose and follow it and tell me where does it go...
help :)
ariesdude
Post by ariesdude »
Its the EGR vaccum hose - it goes to the EGR solenoid valve - Its in page F1-007 on the online manual - look for label "D"
fir3
Post by fir3 »
I don't think this is the hose I'm looking for...
I'm looking for a very thin hose ( like 1milimeter of diameter..) :cry:
ariesdude
Post by ariesdude »
Yup it comes out of the airbox on the left side (if you are facing the car) and goes under the distributor and goes around the vale cover. It is THE thinnest hose in the hole vaccum system. In the diagram it looks thicker than it is on the car.
azazel95
Post by azazel95 »
Mines not connected I just got it plugged with a screw :?
fir3
Post by fir3 »
Just tell me if I'm searching the correct hose:
in yellow...
azazel95
Post by azazel95 »
Yes
fir3
Post by fir3 »
didn't find...
The end of the hose I have marked in yellow is the one connected to the air box ?(not to the air hose)
azazel95
Post by azazel95 »
Ok, on the actual air box where the air filter is in, if you are looking at it from the front it is on the left side. It is the only hose port on that side of the box. Acording to the diagram, the hose labeled D is that hose. The diagram shows it much bigger then it really is but trust me that is it. The diagram might not be 100% correct either.
fir3
Post by fir3 »
let me explain my situation:
Months ago I asked a mechanic to install my cone air filter and remove the stock air box... He installed ok and he hid that tiny hose somewhere in engine bay...
Now I purchased a Cold Air Intake with the connection to that hose...
But now I could not find the hose... :lol:
ariesdude
Post by ariesdude »
Did you look near where the wires from oxygen sensor plugs into the engine harness - the hose has a clip that sits on top of that connector and holds it in place -
or you can go back to the mechanic and ask him to find it for you.
azazel95
Post by azazel95 »
Do you even need the hose attatched? Mines not it is just hanging there with a screw in it to plug it. No prob with it like that either. I'm sure the mech plugged the hole (should have anyways) so maybe you don't even need to worry about it. But maybe you do what do I know :?
