Removing Decals
- The Dark Prince
Removing Decals
Greetings to you all,
I just bought my MX-3 a couple of weeks ago, but there's one thing that bothers me. It had these hideous decals on the side. I've been trying to remove them this weekend, but it took me about an hour to remove just a little bit (i tried it with my fingernails). Does any of you know an easier way to remove decals from a car? It looks like it's been on there for a while, because it breaks off when i try to remove it. Your contribution will be much appreciated...
The Dark Prince
The Dark Prince
"Power Is All That Matters In This World, Everything Else Is Just An Excuse For The Weak.."
schuttie2002
and if you dont have one, a hairdryer always works. It is tedious work but a little heat goes a long way
- PATDIESEL
You can also buy some adhesive remover from Wal-Mart that will make it peel off pretty easily. It also removes the gummy crap (adhesive) that most stickers leave behind.
Alittle easier than a heat gun IMO. but both work.
StylinMike
- happyclown
freakyalien
Casey Gardiner
Yea. Takes a little longer but it's done the same way.freakyalien wrote:Would you remove the pinstripping down the side of the car the same way?
Casey Gardiner
'93 Mazda MX-3
'93 Mazda MX-3
- The Dark Prince
Frankly, i'm kind of hesitant to be standing in front of my house with a damn hairdryer in my hands.. What about my reputation
Perhaps i can find a more secluded area to do this
By the way, to get the remains of glue off my car there are lots of substances that dissolve the glue, but isn't it harmfull for the paint?
The Dark Prince
The Dark Prince
- bushidosword
Look into stuff called GOO B GONE!
You should try a test area to see if it will hurt the paint, but this stuff is awesome!!!
Good luck!!
Good luck!!
Last edited by bushidosword on November 9th, 2005, 5:50 pm, edited 1 time in total.
_____________________________________
Mnemonic
i've used finger nail polish remover and it works great, doesnt mess up the clear coat and eats through the glue, then just follow up with a lil soapy water.
01 Lexus Is300 (LS2 Project)
93 Mx3 SE 2.5 KLZE (sold it)
- The Dark Prince
Thanks a lot guys!
I used a hairdryer to remove the decals and it worked like a charm. Took me about half an hour, but it got the job done.. Just need to remove the glue remains and then use carpolish to make my ride bling even more
Black is beautifull..
The Dark Prince
The Dark Prince
