Purchased front strut bar. Opinions.
fir3
Post by fir3 »
I've purchased from ebay a front strut bar for my mx3 4cyl '97
The link is: http://cgi.ebay.com/ebaymotors/Quality- ... QQtcZphoto
Did I do a good purchase ? Will I feel any improvements ?
Thank you
Grants
BANNED Member
Post by Grants »
You'll definitely feel an improvement in cornering. Well done and enjoy it! :2thumbsup:
neutral
Post by neutral »
You should feel noticeable improvement in steering response on all roads and at all speeds + consistent better tracking across road surface irregularities (reduced "bump-steer") + reduced body roll thru turns. Turns can also be taken at noticeably higher speed with the car maintaining a nice flat attitude.
Install that puppy right away. Only takes a few minutes. With the car on a flat surface, install it in a snug but neutral position so you don't put a pulling/pushing tension on the strut towers.
Image -Jim
fir3
Post by fir3 »
thank you guys !
StylinMike
Post by StylinMike »
Make sure to torque ur strut tower bolts to the right specs as well :D
Vanished
Post by Vanished »
hey it sais that its only 1993-1997 i'm sure its gotta fit 92 too hey?
1992 Blaze MX-3 GS *R.I.P.*
1993 Blue 93 SE-ZE
http://www.cardomain.com/ride/2770987/2
