[WTB] Throttle Cable Bracket
As the topic says, I need one from a K8, and the one that attaches to the Throttle Body. Ill give somone 5 bucks for it!
no one???
ill try to get one at the jy when i go wednesday.
DONATE TO MX-3.COM
DONATE TO MX-3.COM
Awesome...I wish I had a worth-while junk yard around here. Theres a You Pull It about and hr away that usually has nothing, and the local jy has no v6 mx3's.
Im sure you know what piece Im talking about. Also how hard would it be to get the entire cable?, cause where mine attaches to the firewall it has a crack that looks like it may break soon. If its a b of a job dont worry bout it though
i got one layinjg around, ill let you know.
-hec
What the bracket or the entire cable?
bracket.. i can get the entire cable for around 30 dllrs at a local yard.
-hec
well if Gro Harlem can't get the stuff, Hec ill get it from you, but he offered first lol
they only had one mx3 there and oddly it was a 92 CANADIAN model...had manual belts & precedia sticker on the back.
so yeah...i couldn't get it
DONATE TO MX-3.COM
DONATE TO MX-3.COM
ok np, thanks anyway though...hec can I get that bracket from ya???and the cable whenever u go to the jy
0 for 2. anyone else have the bracket
well it bolts onto the throttle body with the use of 2 bolts, I believe 12mm, and then it has a C the the throttle cable goes thru. The cable has a rubber bushing that goes inside the C and is tightened down. Does that help
i couldnt fijnd it the straight nneck ze bracket wont work, has to be a curved neck.
-hec
