KLZE
em-ex-3
KLZE
Post by em-ex-3 »
How much did your full KLZE swaps cost??
vozaday2000
Post by vozaday2000 »
search.
$1300 for engine
then there is the amount for the ecu (approx $320)
then you will need a flywheel (from $200 - $500)
and if you have an automatic you will likely have to swap to a manual.
plus whatever parts need replacing
for me it costed approx $2650. but that was with clutch, fidanza flywheel, exhaust, mixing the fuel lines and taking it to the shop ($500) :evil: . replacing a 02 sensor. and a couple of other things.
prices are in CND
EDIT
sorry that is supposed to be a clutch not flywheel, my bad
Last edited by vozaday2000 on October 13th, 2005, 11:29 pm, edited 1 time in total.
em-ex-3
Post by em-ex-3 »
wow alot cheaper than i thought... i always wanted a honda crx ... i had one and recently sold it... the car is sh*t with out a sway and they are like 5000- 6k for a good one... my uncle has a 1992 mx-3 for me... ill have that soon
Vanished
Post by Vanished »
yah i've acculy tracked down a coupel for 800 ish and my dads buddy works at Kelsea (its a technical institute) and him and his students can do the swap for me for free, and I'll help out abit too. It could range anywere from 1500 to 3000 depends what goods you put on.
1992 Blaze MX-3 GS *R.I.P.*
1993 Blue 93 SE-ZE
http://www.cardomain.com/ride/2770987/2
shawno
Post by shawno »
Hey bud yea i did the swap i paid 1500$ for my engine but i also got a free tranmission with it that i sold for 400$ and i got a ecu of ebay for 200 $ and if u put the motor in your self u will save a ton of money shops will charge u like the same price and what u paid for the motor. so i had the swap done for like 1300 bucks not bad at all and it works super at the track i was doing 14.5 seconds with nothing done but the motor.
mr_icez
Post by mr_icez »
hey theres a place in van. Canada that sells the klze, 5pd and ecu for $2000, then u just have to put it in or find a shop.
