1st Mx-3 Dyno Run
1st Mx-3 Dyno Run
- mitmaks
nice vid
What i find interesting is that you can see the engine torquing back, that looks so cool
MazdaSpeed motor mounts...
- babyblueMX3
Re: 1st Mx-3 Dyno Run
how much power did you make ?Nd4SpdSe wrote:Thanks to Oscar from PakfeiferTuning.com for recording it for me!
http://media.putfile.com/mx-3dyno
*never mind just saw it in your sig.
RIP 400whp ZE-T MX-3
Just to show
- babyblueMX3
you start loosing power at 5.6K, wow, my guess is you ahve the kl01 cams in right ?
a/f is off man..ouch..too rich..now I can see how the megasquirt can benefit a lot on a n/a engine.
this things needs a little tune up and she'd be good to go
this looks close to a klde dyno
Yep, 01 camsbabyblueMX3 wrote:you start loosing power at 5.6K, wow, my guess is you ahve the kl01 cams in right ?
Look at my A/F around 6k, i go to ultra lean.
Sad now it looks like a DE dyno, I definitely have a ZE, with the following mods:
PRM CAI (Dyno'd with on and off)
New Plugs & Injector flush a few weeks prior
OBX Headers
New O2 sensors
2.5" Exaust
Hi-Flo Cat
Walbro 255lph (non-hp) fuel pump
New fuel filter
New fuel lines
New Fuel tank
- babyblueMX3
oh crap..I thought that lean spot was because you let off throttle
- babyblueMX3
dyno = whp
you are talking about crank hp here
2 different things
2 different things
Not at the wheel, no way. A KLZE itself makes 198hp...than take in effect into restrictions from the engine itself, the drivetain, even the friction of the wheels, every single thing that affect the engine, directly or indirectly will take away from that 198hp. A typical dyno for a KLZE is about 160-170hp at the wheels
http://www.geocities.com/MotorCity/5335/zevs03.htm
http://memimage.cardomain.net/member_im ... 3_full.jpg
http://www.geocities.com/MotorCity/5335/ze9397.htm
