Ack! Alright, almost everytime i turn the wheel more than a half turn on my MX-3 the blinker goes on, left or right depending on which way i turn the wheel. Now when i use the blinker to turn, and it clicks off after a turn it jumps over the off position and into the on position in the oppsite direction!
I know this might be a stupid question but i think something is wrong in the steering colum(sp?) with this one.
Any suggestions on what i should look at?
Crazy Blinkers!
Well it certainly sounds like a mechanical (as in physical) problem and not an electrical one. I'd suggest dropping the shrouds off the steering column (a few philips head screws going up from the bottom) and having a look at the switch. Hopefully its just come loose or something simple like that.
- papa roached
mine did that from when i was working under the dash and put to much weight on it and moved it, i just sat int he seat and pulled it back out to where it dont do it no more
