UK MOT - Track Rod End Failure
Posted: September 23rd, 2005, 8:17 am
by UKMX-3
Just had my car in for its annual MOT,
Failed on two items
Drivers Side Rear Shock Absorber - £131
and
Track Rod End needed replacd - £100
Steering re-alingnment - £ 40
MOT certificate - £ 20
With Labour comes out at £350 - Ouch
So can someone tell me what the hell a Track rod end is and what it does?
Posted: September 23rd, 2005, 9:48 am
by snellgrove
I believe its suspension related!
but I am not entirely sure what
sorry!
sucks that the bill is that high, but I suppose you are used to it? I know I sure am, my car happily punches huge holes in my wallet from time to time..
not enjoyable, but price you pay I suppose for a car like ours
Posted: September 23rd, 2005, 9:52 am
by UKMX-3
Well the Mechanic said it was steering/Suspension so i'm happy to pay for it because i've had some funny noises coming from the front wheel area for a while now.
Hopefully its all good now and i can get some quality mods done to my car.
Posted: September 23rd, 2005, 12:32 pm
by lakersfan1
I'm guessing that's the term for 'tie rod end' on your side of the pond? Mine only cost $13 U.S. though and I replaced it in 20 minutes on my own. You do need an alignment after a tie rod end, though. That's crazy that your inspections look at suspension components though. Is the MOT done by independant shops, or by a government run facility? If it's an independant, they may just be trying to ream you for extra money. They tried doing that to me in the state of Nevada where the emissions inspections are done independantly, they tried telling me they could 'get it to pass' for $300. I drove straight down the block to a facility that only tested and didn't offer mechanic services, and I mysteriously passed with flying colors.
Posted: September 23rd, 2005, 7:49 pm
by Rick Johnson
Count the turns it takes to remove it and put the new one on the same way, you will still need an alignment but it won't be totally wacked. You can rent a tie rod puller or a pickle fork usually for free, the puller is better.
Posted: September 25th, 2005, 2:25 pm
by BADMX3
it's about £25.00 for the track rod end and i'm no mechanic but i replaced mine...
but including labour you probably paid about right
Posted: September 26th, 2005, 3:59 pm
by garfy1981
Ouch on the shock absorbers !!!
I got bilsteins for about £70 each.
Pays to shop around !
http://www.provenproducts.co.uk they have been the cheapest on everything ive wanted, ( suspension, brake pads, black diamond discs )
Re: UK MOT - Track Rod End Failure
Posted: September 26th, 2005, 7:51 pm
by neutral
UKMX-3 wrote:...So can someone tell me what the hell a Track rod end is and what it does?
Track Rod/Tie Rod - same thing. This link gives a good explanation of its function along with a pic.
http://www.carcare.org/Steering_Suspens ... _rod.shtml
