window gets stuck
window gets stuck
ok, i know i saw a thread on here about stuck windows... i tried searching for it and cant find anything...
so when i roll my window up, it gets half way up no problem, but at that halfway point it gets really really hard to roll up...
its so hard that u can see the outside of my door being pulled in i have to pull on the handle so hard... how come this happens? i looked at the inside of the door where the window sits and it doesnt look like anything is wrong..?? maybe there is and i missed it... any info would be helpful
i dont have power windows, these are nonpower
- neutral
Check out this link w/special attention to David Witherow's fix - 1/2 way down page one, and also Pat Diesel's recommendations for track lubing. You'll also find a link in the same thread to a Mazda Tech Svc. Bulliten (TSB) for this prob on MX-3's with '92 and '93 manufacture VINs (some drivers claim later years affected too). http://www.mx-3.com/phpbb2/viewtopic.ph ... c&&start=0 G'luck.
![Image](http://i116.photobucket.com/albums/o32/jimfyp/picnic4.jpg)
I've done this on a different car with a slight adjustment (only a couple of millimetres) and worked fine.neutral wrote:Then either David Witherow's fix on the thread/link I posted, or the TSB fix linked within that same thread would seem to be the prob. Try David's fix first - just involves tightening a couple screws.
- neutral
Power window probs can get slightly more complicated by a wider variety of probs and their causes due to having a motor and actuator that can go bad but lubing the actuator tracks is also a reported prob/fix on older models (like any car with old pwr windows) As for the pass side, it would probably be an equally reported malfunction if it got used as much as the driver side window... whether manual or power.
neutral wrote:Check out this link w/special attention to David Witherow's fix - 1/2 way down page one, and also Pat Diesel's recommendations for track lubing. You'll also find a link in the same thread to a Mazda Tech Svc. Bulliten (TSB) for this prob on MX-3's with '92 and '93 manufacture VINs (some drivers claim later years affected too). http://www.mx-3.com/phpbb2/viewtopic.ph ... c&&start=0 G'luck.
link does not work,where can i find this information?
- Tunes67
here is the fixed link:
http://www.mx-3.com/phpBB2/viewtopic.ph ... c&&start=0
Also.. if you check out the main MX-3.com home page (not this forum area) you will find a section of TSB's (technical service bulletins) and this issue has been covered in that section and how to fix & resolve the issue.
Tunes67
Tunes67
"So long.. and thanks for all the fish!" "Momma says VW Bugs are the devil" "This one time at band camp.. I stuck a flute in my Throttle Body" ![Wink ;)](./images/smilies/icon_wink.gif)
