Oil leak at High RPM
MX3driver
BANNED Member
Post by MX3driver »
hey everyone.. I'm brand new to my new brilliant black 95 MX3.. I love it. Just wondering why I can smell a VERY little bit of oil at higher RPM's.. when you are easy on the throttle.. no smell at all.. and it NEVER burns that famous blue smoke.. anyone have a fix or any idea what it is.. thanks alot everyone
Craig
Ive been banned for moronic childish behavior.
MX3driver
BANNED Member
Post by MX3driver »
Any Idea's anyone.. open to pretty much any hints..right or wrong.. haha. basically troubleshooting
freyguy_412
Post by freyguy_412 »
The only thing that comes to mind would be the PCV valve, but I've never experienced the symptom you describe. Total shot in the dark. Pull the pcv valve out, pull it off the vacume line and shake it. You should hear it rattle back and forth a lil bit. Also check the dipstick when the car is running, maybe even after you've reved it up a bit. If you get any kind of smoke out of that pipe where your dipstick is, replace the PCV valve.
It might be slow, but it's not a civic!
Mazda_Power
Post by Mazda_Power »
freyguy_412 wrote:The only thing that comes to mind would be the PCV valve, but I've never experienced the symptom you describe. Total shot in the dark. Pull the pcv valve out, pull it off the vacume line and shake it. You should hear it rattle back and forth a lil bit. Also check the dipstick when the car is running, maybe even after you've reved it up a bit. If you get any kind of smoke out of that pipe where your dipstick is, replace the PCV valve.
The PCV valve acts as a check valve. Suck on it and see if it only allows air one way. (MMMMM isn't oil tasty!) Next the oil pump on any car (as long as it's mechanical) will increase oil pressure as RPMS rise. So the higher your RPMs are the more likely you are to leak oil. Furthermore, I'd say that maybe your valve seals are bad. How many miles on your motor? Have you ever done a comrpession test?
'92 Festiva L powered by a 1.8L SOHC Protege motor - For Sale
MX3driver
BANNED Member
Post by MX3driver »
Just got the car about 2 weeks ago.. so I havn't done a compression test on it yet.. and it's got around 278,000kms.. alot i know, but runs amazing.. minus the high RPM oil burn!!
KEEP THE IDEAS COMING!
Typhoonk
Post by Typhoonk »
so you smell it in your car when idling, or when driving?
cause it could just be an exhaust leak that's being sucked into your
cabin via the vent. do you have a layer of film on your windsheild? wipe with a cloth and see
PM for info
MX3driver
BANNED Member
Post by MX3driver »
s---.. never thought of that.. but if you give it really high rpm.. 7grand or so. it'll shoot a little blue smoke..
so i don't think it's that.. but im gonna check anyways
keep em comin'
Mazda_Power
7K? My B6 will only rev to 6550 then it hits fuel cut. :(
MX3driver
BANNED Member
Post by MX3driver »
yeah mine will hit 7500 before fuel cut..
Mazda_Power
Sure it isn't a V6? Seems odd, maybe there's something I don't know.
MX3driver
BANNED Member
Post by MX3driver »
Nope... 16valve dohc.. only thing on it i can see is the cold air intake.. nothing special.. I don't know if the guy that had it before me did something special or not..there definately isn't anything visually standing out done to the engine
Mazda_Power
Wow... must be a '95 RS thing.
