This is the kit that was intended for the mx3 but I had been extremelly busy making a set of projector lights/ engine swap/ work/ work / work and girlfriend. Here is the finish product..if anyone would be interested well let me know. We are making yet anoither copy..this one here is a copy..the original we used them as molds and made them into a tick cast. Note that it would not come with ze inserts ..those were gotten of a washer dryer combo..lol the rear vents were aquired via ebay.
-hec
I can take tons of more pics if you want. My cell phone camera doesnt loike the sun much... 1.5 megapizle my arse :/
-hec
Parts needing installed: turbo kit from BB (if i ever get it), 9.0:1 CR Diamond pistons, 4340 forged H beam rods, C/J-Spec spoiler, Nissan red tops in KL rails http://www.cardomain.com/id/blazejeremy
So this "cavalier" isnt made by mazda? Are you sure?
I also remember hearing something about "multiport fuel injection" and a possible displacement of "3.1", and being informed that if challenged it can "lay a strip" from a red light.
Franko wrote:So this "cavalier" isnt made by mazda? Are you sure?
are you serious that there are no Cavi's up in Newfoundland? wow
These things as utter POS's and run mid 16s at best. They used to be either 2.2L or 2.4L 4 bangers, dunno what these new ones are. Still slow... my stock GS took their doors. The ZE blows them off the road.
bahahah.....franko your funny..."what is a cavalier" lol
