Last tuesday I noticed that when I would stop the car and let it idle for a bit white smoke would come out the tail pipe once I took off. First thing I thought was ' s---, headgasket gone' I always noticed that the compression on cyl #2 was always a little lower then the rest so I decided to bring it in and have it checked. After taking out the spark plugs we hooked up a pump to pressureize the cooling system and cyl #2 filled right to the brim with coolant and steam came out of cyl #1. So I could only assume the headgasket was gone. Got the engine taken apart right then and there and the head gasket looked a little shady but not completely gone. Anyway I brought the head in to be planed and pressure tested and see if it was warped. A couple of hours later the guy who ownes the place called me and told me the words no one wants to hear.. "Your head is cracked in 2 places and will have to be sent away to be fixed." Apparently the engine was overheated badly before I even owned it causing the head to crack and possably even warp.
At a cost of 400 - 500 dollars to get it fixed and it not guaranteed to be perfect afterwards I immedately bought an entire N/A BP engine out of a protege since just the head by itself is hard to come by around here. Also apparently there is HP to be gained from doing this swap since there is no head restriction in the N/A head and there is in the BPT, So its really an upgrade that im somewhat forced into.
Me and a buddy of mine went to pick up the most sketchy engine Ive ever seen. It actually looks like it got pulled off the bottom of the ocean by someones fishing net. We took the head off the engine right in the back of his explorer and stripped it down to get ready to be sent in to the same guy.
I just got the head back tonight. Its MINT! Switched over the BPT cams/valves/springs in to the new N/A BP head. Machined pressure tested and cleaned up its as good as new.. So hopefully Ill be pimpin in the mx again tomorrow.
Anyway check out the pics...
Right off the bottom of a lake..
In the back of the truck.
![Image](http://www.modifiedmazda.com/files/Images/Head/Lake%20bottom%203.jpg)
![Image](http://www.modifiedmazda.com/files/Images/Head/lake%20bottom%202.jpg)
![Image](http://www.modifiedmazda.com/files/Images/Head/Cover%20off.jpg)
Crack in the head..
![Image](http://www.modifiedmazda.com/files/Images/Head/crack.jpg)
Boxes with the old valves and head and cams..
![Image](http://www.modifiedmazda.com/files/Images/Head/Box%20of%20goodies.jpg)
And the new one all cleaned up..
![Image](http://www.modifiedmazda.com/files/Images/Head/Cleaned%20up.jpg)
![Image](http://www.modifiedmazda.com/files/Images/Head/Cleaned%20up%202.jpg)
![Image](http://www.modifiedmazda.com/files/Images/Head/Cleaned%20up%203.jpg)
![Image](http://www.modifiedmazda.com/files/Images/Head/Cleaned%20up%204.jpg)
And you can see plain as day the head restriction in the bpt head..
BPT
![Image](http://www.modifiedmazda.com/files/Images/Head/head%20restriction.jpg)
BP
![Image](http://www.modifiedmazda.com/files/Images/Head/bp05%20head.jpg)
Anyway I have to take off and bring the head up to the shop.. Let me know what you guys think of it all.
