Squelling Noise when engaging clutch
Posted: September 13th, 2005, 3:26 pm
by kev259
Had this problem ever since I first bought my mx3. Have since dropped in a ZE, new clutch. It happens when I engaging the clutch moderatly heavy. If I'm real easy on it it doesn't happen at all.
Posted: September 13th, 2005, 3:52 pm
by lakersfan1
Is the squeek coming from inside the cabin or in the engine compartment? In engine compartment, I'd ask if you replaced the throwout bearing when you put the new clutch in? If in the cabin, grease the pivot points of the clutch pedal and the shaft of the cable when pedal is fully depressed.
Posted: September 13th, 2005, 7:13 pm
by hgallegos915
this exact thing happened to me..it turned out to be the release bearing.... it dies and then the teeth broke..car lasted a good 3 weeks making this noise... then BOOM..i couldnt shift.. I had to flopat gears all the way home..not fun at all.
Posted: September 13th, 2005, 7:21 pm
by Grants
Sure its not a belt noise?
Posted: September 14th, 2005, 1:19 pm
by kev259
I think it's coming from under the hood. Weird thing is this has been happening for years, never affected the driving/shifting. The clutch engages perfectly, just makes that damn noise!
Posted: September 14th, 2005, 3:36 pm
by lakersfan1
So you did a ful engine swap and new clutch, but didn't replace the bearings?
Posted: September 14th, 2005, 4:14 pm
by kev259
Hmmm, I dunno. I had someone do the swap for me(Travis Williams). Where are the bearings? Sorry I'm not to car savvy...
Posted: September 14th, 2005, 4:16 pm
by kev259
Just to clarify, this only happens while engaging the clutch, once it's in gear the sound is gone....
Posted: September 17th, 2005, 6:27 am
by mdavis
I think throwout bearing, too. It's located right in front of the clutch disk inside the transmission bellhousing - a day or two's work for someone familliar with the car, or something like $500-600 for a shop to do it... sorry, man
Posted: September 18th, 2005, 9:36 pm
by kev259
Yeah that's kinda what I thought. It's coming from the engine, guess I'm going to have to have someone look at it. On a side note, does anyone know a good mechanic in the Denver area that has experience with mx-3s?
Posted: September 18th, 2005, 11:23 pm
by Slammed6
You should have someone press the clutch in and stand in front of the car and try to pinpoint the area the sound is coming from.
Posted: September 19th, 2005, 9:26 am
by kev259
Good idea, I'll try that tonight.
