I was bored this weekend and....
vozaday2000
Post by vozaday2000 »
I decided to install some tweeters in my car. Now i saw that there was enough room in the area where the side mirror sits and decided to modify it. Here are some pics.
I noticed the blacks clashed so here is a off colour pic:
Here is some after installation:
GregoryChristian
Post by GregoryChristian »
never thought of that before ...I recently converted my manual door windows to power and was thinking of installing some tweeters in the holes of my door panels where the crank handle was located
vozaday2000
that would work. mine always had power windows (since i owned it anyways) so i had to come up with something different
2fazed
Post by 2fazed »
Is that a crossover unit on your door panel? You can put them inside your door, there is room.
06 Mazdaspeed6 2.3T
93 626 ES 2.5
92 Mx-3 RS 1.6
93 Mx-3 GS 2.5
93 Mx-3 RS 1.6
vozaday2000
ya i realized that, it was just that i thought it would look kinda neat. i think i need a better looking crossover though.
mitmaks
Post by mitmaks »
nice setup i like it
Insanebabe123
Re. Tweeters
Post by Insanebabe123 »
Did you modify with fiberglass? How dificult was it to do. I like the look and would like to add it to my ride once I fix the Master cylinder and resolve the hood issue with G-Force Customizing
Lee {Insanebabe123} :twisted:
'95 MX-3 RS Black on Black on Black
First car and First project
Hoping to have it complete by the time I get my License
Solo
Post by Solo »
how did u make it ?
was thinking of the same things but didnt had a clue on how to do the smooth edge and everything..
BooYaH Screaming Team
http://solo.monchar.com -> 15,871@88,5MPH -> Top speed 230km/h
http://stuart.monchar.com -> building in progress
RaVeR 4 life BabY!
got a Protege 1.8 SOHC 4x4 for winter ^^
vozaday2000
well first i took out the inside mirror piece, then i made a cone shape out of construction paper. then i used the mat fiberglass and put a piece over to get the shap of the cone and to attach it to the inside mirror piece. then i laid a couple of lays of fiberglass until it seemed strong enough and was in the basic shape. then i sanded it and used bodyfiller to fill in all the nooks and crannys. I also used the body filler to improve on the shape. then i sanded the bodyfiller down and primed it with the walmart emanul primer and then painted it with the emanul spray paint. here is a pic of it after the bodyfill and fiberglass, as you can tell it is mostly covered with bodyfill (I found it easier to sand).
Typhoonk
Post by Typhoonk »
when I get bored on the weekend I just sleep. Props for getting up and doing something cool
PM for info
Urbanconcept
Post by Urbanconcept »
Nice work. Seen it done lots of times. Its a perfrect spot for tweets. Im sure you can mount the crossovers inside the door, that will look a ton better than being visible.
Friendship is like pissing your pants: Everyone can see it, but only you can feel its true warmth.
Return to “Appearance”
