Oil leak near distributor
Posted: September 4th, 2005, 6:11 pm
by ariesdude
I think my engine (94 1.6L DOHC) leaks a small amount of oil somewhere around the distributor. The entire distributor is caked with greasy grime and there is some greasy stuff close to the cylinder - also i found out that the spark plug gets covered with oil (the one closer to the distributor) - so i am thinking that the valve cover gasket and the distributor gasket (if there is one) both leak. Is it easy to change both those gaskets? Is it as easy as take the valve cover off - put the new gasket in - take the distributor off - put the new gasket in etc... Also if i take the distributor off - should i have to do tuning/timing adjustment etc etc. Thanks.
head gasket repair
Posted: September 6th, 2005, 12:13 pm
by WTF
Repairing the gasket is not very difficult.
Just keep in my the spark plug # sequence if you dont have a book.
Clean everything, no grease, brake cleaner or something. Dont go crazy overtorquing the cover bolts or else you will eat the thread in the aluminum head.
Posted: September 6th, 2005, 12:35 pm
by ccreech
The disty o-ring is easy to replace. I replaced mine when I did my swap about 4 months ago and it is leaking a little bit already. That is a tough hole to plug. I would suggest buying Mazda's disty O-ring if they have one. I just tried to match it up s good as I could from a selection of O-rings that Napa had. I THOUGHT that it was perfect.
The Valve cover is also an easy fix. As WTF said...the key is don't over tighten. The head of the bolts will snap off I guarantee it. A torque wrench is a wise investment. A dab of RTV...Gasket maker from any parts store... is a good idea in the creases where the cams run.
Advanvce sells a kit with the valve cover gaskets and Grometts. I don't think anyone sells just one. The rear one is a little trickier to get to because you have to take the intake off but its not that hard if you know what you are doing. Just don't forget about the bolt that is hidden way in the back that keeps that bolts the intake to the rear head.
Happy Wrenching!
Posted: September 6th, 2005, 2:54 pm
by ariesdude
Thanks a lot for the help guys. I cant find mazda distributor gasket/o-ring anywhere locally - do you guys know what kinda gasket/o-ring i can substitute (size, make etc) (for 4 cyl 1.6L DOHC distributor). Thanks.
Posted: September 6th, 2005, 4:14 pm
by ccreech
Like I said I went to NAPA with my old one and matched it up as good as I could. However mine still leaks a little. Not as bad as before though. Napa replacement might be better than your old crappy one. They are like .50 too so you can't beat that. I bought the 2 that were the closest in size and tried them both. One appeared to be perfect...Maybe Mazda designed it to leak a little????jk
Posted: September 13th, 2005, 6:29 pm
by Mazda_Power
Just try and find another o-ring, maybe a little thicker, but same diameter. Get a new valve cover gasket and get some gasket sealer and your problems will be solved!
Posted: September 14th, 2005, 12:43 am
by ariesdude
Thanks man - i did change the valve cover gasket and i took off the distributor and surprise - there was no o-ring at all - i just put a whole lot of gasket maker in there and formed a custom o-ring and it doesnt leak anymore - i dont know if that's a permanent solution - but it was the only one i could come up with my limited time and resources ...
Posted: September 16th, 2005, 2:36 am
by Devilhog
My Distributor was leaking, I took it into the shop, and being young and stupid they told me there was no way to change the O-ring so they had to replace teh distributor.
Ya that gasket sealer and a O-ring close to the size works great, which I found out after I shelled out money for a new Dist.
Posted: September 16th, 2005, 10:29 am
by ariesdude
yes - i dont know why car mechanics feel the need to overcharge and fleece us at every possible oppurtunity. I went in for an oil change recently and the dude asked me for $25+parts to change spark plug/ wires and $75+parts to put on my new muffler and 75+parts for a fuel filter! I know there are honest mechanics out there - i just cannt seem to find them
Posted: September 16th, 2005, 12:15 pm
by mycarhatesme
honestly....dont feel so bad...i bought my mx3 in may, its now september...ive had these problems....
water pump (current issue) --- 100$
4 new tires. --- 65/each.$
new alternator --- 200$
new trailing arms..both sides... --- 250$
new rad --- 150$
windshield has a crack in it...not looking good.
i got gas spitting out my muffler tip...not looking good.
i have no mechanical experience....
lol....again...dont feel so bad.
Posted: September 16th, 2005, 5:10 pm
by ariesdude
mycarhatesme wrote:honestly....dont feel so bad...i bought my mx3 in may, its now september...ive had these problems....
new rad --- 150$
I have some mechanical experience and i am confident that i can do it if i had the time and tools and of course money..... and i dont have much of all the above...... as somebody once said - life sucks - but the alternative is not pleasant either....
Posted: September 20th, 2005, 3:11 pm
by mycarhatesme
lol...u said it.
