need help ASAP
- fieromx3
need help ASAP
i just put new front pads on and now my brakes go right to the floor!! there is no air in the lines and my fluid is topped up. i did only the front pads and did is as per the instructions and they r on EXACTLY the way they always were. i need help now to make it to cayuga tonite.
they always take time to work properly again because when u take off the pads you will most likly depress the piston inside of the caliper and well yah it does take a short while for the brakes to feel normal again
um you need to bleed your brakes...its a must when the pedal goes to the floor..even if its topped off.fieromx3 wrote:well my brakes r workin now but no i didnt bleed themCustommx3 wrote:Have you bled your lines @ all?
-hec
- fieromx3
i said i didnt need to bleed brakes becuz i never took the lines off or loosened or even touched the brake lines and my dad just took it out for a test drive and he says its more than likely my master cylinder. he was a mechanic so he porbly is right. he also said my transmission is a POS and it doesnt got no snap to it lol
