I got in an accident with my car so I'm now in the midst of painting it and read posts about shaving the antenna. I don't use my radio at all but wanna know what it looks like without the antenna. Please post pics or links without the antenna.
Thanks KR
Shaved Antenna??
http://www.mx-3.com/phpbb2/viewtopic.php?t=44712
That thread, 4 pics down. Still primed though, hasnt been painted yet.
I also had the grooves on the roof filled in.
-Tim
-Tim
Don't park drunk, accidents cause people.
92 Blaze Red MX-3 GS, KL-ZE, ACT Clutch, KL 36 ECU, SS Clutch Line
- ovendenk
here's mine that's been painted. it looks a lot better imo.
kevin (aka The Oven)
93 mx-3 GS KL-ZE with KL31 cams and properly chipped ecu
All mods are on my website: http://ca.geocities.com/ovendenk
MX-3.com Worklog: http://www.mx-3.com/phpbb2/viewtopic.php?t=48462
- papa roached
gorgeous color
- jschrauwen
There's a lengthy post on this subject last winter that also included re-locating the antenna to the rear window washer spot and routing the antenna to there. A Euro type stubby antenna was utilized in that location and suited the car quite nicely. Try the search for it - it's a good read.
- ovendenk
thanks man. i really like the way it turned out.papa roached wrote:gorgeous color
