maf/vaf
hgallegos915
maf/vaf
I heard the kfze in comeswith a maf... not a vaf..is this trues and can I get one anywhere???? I saw a millenia with a maf..
-hec
- Aston Wards
hgallegos915
I already got the kfze ecu.. would that work? and is it bolt on? (maf)
-hec
- atlantamx3
you cant just put it on, you need to get a stand alone to put one on tofieromx3 wrote:if u put a maf on a k8 how much more power could u get? would it help the bottom end power alot more?
control how the engine breaths and uses the maf.
- fieromx3
well i know that or u could use the maf sensor ecu from corksport but for the money an MS would be way better. im just thinkin takin that football style vaf and puttin a maf on u would think that could give so much more power if it was tuned right especially on the bottom end where it counts most on our engineyou cant just put it on, you need to get a stand alone to put one on to
They are not interchangable
ON the V6's
VAF -> OBDI
MAF -> OBDII
Unless you want to rewire you engine and replace the computer, just to put in a MAF, it's definitely not worth it.
ON the V6's
VAF -> OBDI
MAF -> OBDII
