Alternator change out gone wrong
Ok i have a 92 gs and my alternator went bad. When i replaced it and started the car the engine was only running on 5 cyl. My buddy gave it a little cas and the car died. the reason it was only running on 5 cyl was because one of the plug wires was disconnected. When i reconnected it and tried starting the car it wouldnt start. The car turns over and is getting plenty of spark. I checked all the fuses and let the car sit for a day thinking it was flooded. still wont start...any ideas?
Nitrous is like a really hot girl with STD's. You know you wanna hit it but you're afraid of the consequences.
(\/¯)åzέ
(\/¯)åzέ
- Zoso124
Disconnect the negative terminal on the battery and go depress the brake pedal for 20 seconds to clear the ECU's memory. I've run into some weird issues where I could only get the car to restart after clearing the ECU.
Mike Evans
Gone:
Gone:
