MX-3 on a diet!
Posted: August 24th, 2005, 6:07 am
by Slammed6
Well i bought a 1993 MX-3 GS SE and i weighed it in at 2520 lbs with full interior, completly stock, and about 3/4 tank of gas...and after my quick weight reductions and my ZE swap i weighed the car again and now it weights in a 2240 with approx 1/4 tank of gas.
I saved 280 lbs. not bad... :lol:
I removed pretty much the basics: A/C, Power steering, Interior from behind the front seats back, bumper supports front and rear, and full headliner and sun roof.
Can anyone else help me out with an area they found weighed alot?? Thanks
Posted: August 24th, 2005, 7:59 am
by babyblueMX3
you weigthed the same as me EXACT 2240lbs
we remove almost all the same things.
but now I weight more with the turbo stuff :(
Posted: August 24th, 2005, 12:56 pm
by neutral
Take a look here - might give you some ideas. http://web.archive.org/web/200406022140 ... weight.htm
Posted: August 24th, 2005, 2:06 pm
by Slammed6
I already removed pretty much everything he said. lol
Does anyone know how much the stock GS Leather seats weight???
Re: MX-3 on a diet!
Posted: August 24th, 2005, 6:06 pm
by neutral
Slammed6 wrote:Can anyone else help me out with an area they found weighed alot?? Thanks
FWIW, I saved 9-10lbs when replacing the old lead acid battery with a smaller lighter, but similarly CCA rated Optima yellowtop D51R battery. My MX is a 95 RS so don't know if the CCA would be enough for the GS...
Posted: August 24th, 2005, 6:23 pm
by Slammed6
true true, well the only thing i really have to worry about that drains the batterey is the power windows...other than that i am sure your RS has just as many options as my Gs now.. :lol:
Posted: August 30th, 2005, 10:54 pm
by hgallegos915
if u got power windows... the little motors are sorta heavy.
Posted: November 12th, 2005, 9:54 am
by deathman
hgallegos915 wrote:if u got power windows... the little motors are sorta heavy.
yup he might loose a 2-3 pound's, unless you leave the whole window regualator out, but the piece of wood you put in to hold the window up might wiegh some thing lol
Posted: November 12th, 2005, 9:59 pm
by fieromx3
getting a CF hood could save u 10-15lbs if u dont already have 1
lightweigt rims would also help
Posted: November 14th, 2005, 4:22 pm
by lakersfan1
I believe the power unit for the hatch windshield wiper is kinda heavy.
Posted: November 20th, 2005, 3:44 am
by wazza
If you're really serious about stripping weight & don't mind not being able to roll your window down, remove the complete window and the regulator assy, replace the window with 3/16" lexan. Just jam it up int the bailey channel and fix it in place with a "L" shaped bracket screwed to the frame under the lexan's bottom edge with a couple of self tappers. Glass weighs a lot. You could also replace the rear hatch glass with lexan too.
Posted: November 20th, 2005, 11:30 am
by fieromx3
wazza wrote:If you're really serious about stripping weight & don't mind not being able to roll your window down, remove the complete window and the regulator assy, replace the window with 3/16" lexan. Just jam it up int the bailey channel and fix it in place with a "L" shaped bracket screwed to the frame under the lexan's bottom edge with a couple of self tappers. Glass weighs a lot. You could also replace the rear hatch glass with lexan too.
if he is drivin on streets thats not a good idea as it is not legal. if it were id be doin my rear hatch window :)
