Ok... I got my Autometer A/F guage installed this weekend and just wanted to know if I could compare it's readings to someone elses. I got a K/N filter on the intake hose and a cat back exhaust done to it so far.
At WOT, it dances from about mid lean to the rich side of stoich under 3300-3500 rpm. After that, it usually pegs itself rich about 4 bars down. When I'm decelerating in gear, or the engine is coming down off a rev, the meter goes off the scale on the lean side (I assume cause it cuts fuel to lower the rpms to idle...) I just wanted to see if anyone else can verify these kind of readings so I can establish a base line before I start tuning (Ordering a SAFC in a few months... and yes I know that an A/F guage is only really an approx...) Thanks
Air Fuel ratios...
- freyguy_412
Air Fuel ratios...
It might be slow, but it's not a civic!
- facko
that sounds about like how mine is, and ive got the bigger bp injectors in too. from slight to mid throttle its jumps around the richer side of stoich and when im @ WOT it just barely goes into the rich side, like 3 bars i think. when i had my stock injectors in it was about the same too so, im guessing thats where things should be? lol
BP swap -- Pacesetter Header -- Custom CAI -- Custom 2.5 Exhaust w/ a Thrush Glasspack and 40 Series Flowmaster -- SPEC Stage 2 Clutch Kit
- freyguy_412
Well get atleast an egt gauge as well, I just wouldnt want to see one of you guys posting something up along the lines of It smokes alot and has no power and is making funny sounds...
Oh and btw Im not spoiled and rich i work my arse off or everything i bought on my car including a 7$ an hour job which took me a month to save up for the wideband.
im Not harshing or trying to start a fight but i know your pain.![Razz :P](./images/smilies/icon_razz.gif)
92' Rs-t b6t/De - RIP
93' Rs-t BPT - Sold
03' WRB wrx Wagon - Current
93' Rs-t BPT - Sold
- facko
yea i know what you mean, im not planning on using the a/f guage to tune my whole turbo project off of tho...and im sure freyguy isnt either. id probably have a wideband by now but school started again so
cant work as much
