BPT injector o-ring EMERGENCY
Posted: August 15th, 2005, 7:51 pm
by Cpl_Bryant
So when I first started my BPT, one of my injectors was spewing fuel. Okay, took an o-ring from the old MX-3 injectors and put it on the BPT injector. Seemed to fix the problem. Today I drove it to the muffler shop to do the exhaust work and smelled fuel. When I got there I opened the hood and saw a little pool of fuel on my intake manifold right under that same injector and could somewhat see it fizzing out of the injector. So now I am guessing that MX-3 injector o-rings are not the same as BPT ones. My question is, how can I get those o-rings? Will the ones for the Protege LX do the job? Or do I need to go to a Mazda dealership to order them? Please help. I had to leave my car at the shop 'cause I wasn't in the mood for an engine fire after all the work on the swap. Thanks.
![Crying or Very sad :cry:](./images/smilies/icon_cry.gif)
Posted: August 15th, 2005, 11:20 pm
by JWMotorsports
The 1.8 Pro-LX DOHC Injector O-rings should work fine. The only way to compare them with out looking them up is to use a caliper and measure their approximate size. You could pull measurements on the injector holder boss and get an o-ring w/ .005" larger O.D. then measure the injecror o-ring grove and use that dimension for the ID of your injector o-ring. Use a little seafoam as lubricant when installing the o-rings on to the injectors and then when installing them into the head to prevent sliting the o-ring by accident. Inspect your leaky o-ring to see if it is cracked or split.
Posted: August 21st, 2005, 1:04 am
by Ateana
just get new ones from mazda they are like 8 bucks a piece and you need upper and lower for each injector. so you need 8 total remember upper and lower just get them from mazda trust me i went through that
Posted: August 22nd, 2005, 12:54 am
by Cpl_Bryant
So far so good with the Pro LX O-rings. I only replaced the 1 that was leaking and thus far have had no problems. If it happens again, I will go through the dealer and get all 8.
