Comedy Tyre Change
Posted: August 14th, 2005, 9:26 am
Well just had flat tyre on the front, luckily it was only 2 mins down road from me but anyhow, did take a while !!
Problem number 1; couldnt find the jack anywhere, dont know where thay are usually kept on the mx
So went back home luckily ive got a two ton trolley jack in shed
Problem number 2; as ive lowered car i was about 20mm short of getting the jack under car!! So i had to wait for stranger to walk by so they could push jack under while i lifted front wing !!!!
Anyhow changed tyre for the space saving wheel which looks ummm... pretty. Then had to wait for another stranger to get jack off car again
In all took about 40mins for one wheel !!,
Any ideas about jacks for lowered cars?? a bottle jack would definately not fit, im on standard 15" rims at the moment so theres only 12.5cm from car to ground
