weird engine noise
weird engine noise
I get a weird screeching sound whenever i start the engine after i had parked in direct sunlight for a bit - i dont get that noise when i start the engine in the morning - i park in an open parking lot during the day and when i start it in the evening there is this weird screeching noise - it usually goes away in about 30-60 secs. I checked the fluids and they seem to be fine - so does anyone know what would be the problem. Any help/info is greatly appreciated. Thank you.
- neutral
Sounds like the alternator drive-belt needs to be cked. for correct tension and adjusted if needed. Should have ~3/8" deflection when pressing w/moderate thumb pressure against center of the longest belt span. Don't over-tension though as that can damage the alternator bearings.
The screeching is the noise of the drivebelt slipping around the pulleys and can cause the belt's inner surface to harden w/a friction heated glazing, which in turn, leads to more slipping until eventually, that belt just melts itself into shreds.
![Image](http://i116.photobucket.com/albums/o32/jimfyp/picnic4.jpg)
