New yet old rigidity mod, FOaming ur chassis
DavidOS
Post by DavidOS »
http://www.smooth-on.com/foams.asp
I know mazda miata autox dudes have been doing this.
so if you fill your chassis with this stuff it actually makes a
difference.
recommended 10-15lbs of that stuff
http://www.sportcompactcarweb.com/proje ... proj300zx/
papa roached
Post by papa roached »
its almost like filling your motor mounts with urathane
Gro Harlem
Post by Gro Harlem »
i remember reading that article awhile ago.
definitely something to try. i wonder how much one "kit" costs and how much u can fill with just one kit?
DONATE TO MX-3.COM
Macen
Post by Macen »
Won't that foam make water to stay inside the chassis easier and therefore increase the probability for rust to come up?
Black '93 GS-RL KL-DE
White '95 RX-7 Type R Bathurst
http://macen.nullnet.com
lakersfan1
Post by lakersfan1 »
Macen wrote:Won't that foam make water to stay inside the chassis easier and therefore increase the probability for rust to come up?
If you read the article, it says it forms a closed cell foam. Closed cell foams don't trap water, they repel it. Open cell foams are the ones you don't want to use in an application where water might be trapped.
Macen
Post by Macen »
Ok, I see. Must have missed that part in the article. :)
lstpier
Post by lstpier »
http://www.foamseal.com/auto_aftermarket.htm
1.76lbs/cubic foot, apparently 4-5 kits are required depending on the car type.
Advantage of this kit is that it comes in pressurized cans with a static dispenser (nothing to mix and try to pour down side up in the chassis!)
Tried contacting the company to ship a case/half a case to Canada and would only ship by truck for 150USD. The seem pretty hard to deal with and are not trying to promote at all the product. I've seen a handful of threads only on the net discussing this topic and only 1 person claiming having done it beside SCC.
Any Canadian fellow want to try a BulkBuy and try to drive the shipping cost per kit price down?
