Any body know about this product ?
http://www.mmrusa.com/phantom1.htm
Is it a 1, 1.5 or 2 way ?
Doesn't a 2 way LSD give big understeer on a FWD ?
*Phantom Grip LSD conversion ?
- neutral
http://www.mx-3.com/phpbb2/viewtopic.ph ... antom+grip
Buncha other threads on the Phantom Grip too. Do a BB search w/key words <phantom grip> and select "search for all terms" and you'll get good results.
![Image](http://i116.photobucket.com/albums/o32/jimfyp/picnic4.jpg)
Re: *Phantom Grip LSD conversion ?
Its neither.bigtime wrote:Any body know about this product ?
1-way means it works when accelerating only
2-way means it works when decel and accel.
the phantom grip basically makes your open differential a locked-differential which is NOT a limited slip. The only real difference is it won't be locked 100% of the time. Like if you were driving on snow and one whee is on asphalt and the other is on ice, the one on ice would spin as if you had nothing installed,
but when acceling in a straight line it can be semi-useful to help both wheels hook up ASSUMING both wheels are under asphalt or have traction.
I've only heard good things about phantom grips from dodge neon guys. No one I know who has one installed in their Mazda said it helped whatsoever, but maybe the neon-design works well compared to our car
DONATE TO MX-3.COM
DONATE TO MX-3.COM
